vcFocusModeManager
Represents container for focus mode objects that is used to start Focus Mode feature. Content of the focus set will be kept focused, everything that is not included in the set will become unfocused when focus mode is started.
Referenced by: vcWorld.FocusModeManager
| DynamicComponentFocusSetting | vcFocusModeDynamicSetting | RW | Gets or sets how to display dynamic components during simulation while focus mode is active. |
| FocusSets | list | R | Gets the focus sets that this manager contains. |
| IsFocusModeActive | Boolean | R | Gets a value indicating whether focus mode is currently active or not. |
| StoreContent | Boolean | RW | Gets or sets opacity value for the unfocused objects.See moreValue can be between 0 and 1 where 0 meaning that objects are not visible and 1 no transparency at all. |
| UnfocusedOpacity | Real | RW | Gets or sets opacity value for the unfocused objects.See moreValue can be between 0 and 1 where 0 meaning that objects are not visible and 1 no transparency at all. |
| createFocusSet | vcFocusSet | List[vcNode] nodeList | Creates a new instance of vcFocusSet with given vcNodes. And adds its to the current vcFocusModeManagerInstance.See moreRaises event ObjectSetAdded in case of success. Parameters: nodeList (List[vcNode]): Nodes to be used for the vcFocusSet creation. Will only include supported node types. Returns: vcFocusSet: Created set or None in case creation failed. |
| removeFocusSet | Boolean | vcFocusSet focusSet | Removes given vcFocusSet from current FocusModeManager instance.See moreRaises event ObjectSetRemoved in case of success. Parameters: focusSet (vcFocusSet): Set to be removed. Returns: bool: True if was removed, False otherwise. |
| startFocusMode | None | Optional Keyword[focusSets = List[vcFocusSet]] | Starts focus mode for the given list of vcFocusSet.See moreRaises event FocusModeStarted in case of success. Parameters: focusSets (List[vcFocusSet]): Focus sets to use for focusing. |
| stopFocusMode | None | None | Stops focus mode. Raises event FocusModeStopped in case of success. |
| FocusModeStarted | None | Triggered when Focus Mode started. |
| FocusModeStopped | None | Triggered when Focus Mode stopped. |
| FocusSetAdded | None | Triggered when new vcFocusSet added to vcFocusModeManager. |
| FocusSetRemoved | None | Triggered when vcFocusSet removed from vcFocusModeManager. |
